What I'm missing on the Taycan CT I ordered.....
RobQ
1973 911, Tycan CT
Hyundai has a feature on the car that you can actually use the car to charge other cars and or other equipment bases on the (in Europe) normal 220 volt connection. Which means you could re-charge for example your e-bike. Just wonder why Porsche did not come up with this feature as they are also offering e-bikes. Would be great if you use the car to charge them. I have a e-surfboard which I would be great to recharge using the battery of the car.
Genau
Reston, Virginia
Yes, this would be a useful feature. Other brands have this as well, such as the Ford F150 Lightning: https://www.motortrend.com/news/2022-ford-f-150-lightning-electric-truck-charging-generator-power/
dickp
Dick
VA
www.dickpitini.com
2022 Taycan CT4
lcarron
Laurent
Cross Turismo 4S
I'm sure that you know that you can simiply plug in a power inverter into the 12vt outlet in the back of the CT if you wanted to charge a E bike.
Do you know by chance how many amps you can get out the 12v outlet in the trunk? I think you need a good 15 to 20 amps. Any advises?
juuso
Finland
CT
Here's what the Good to know app says:
The maximum load capacity of a 12-volt plug socket is 20 A but only if one load is operating. Do not exceed 10 A load per 12-volt plug socket if several loads are operating simultaneously.
