DerekS
- Derek
- May 25, 2021
- Frisco, TX
- 2023 Taycan GTS
The real question: did you find out what happens when you find a stranger in the Alps?
Yes I do. It is standard in the CT in Belgium. For road trips in Europe it is important as multiple 400 V chargers are available and would only be able to charge at those at 50 Kw. I also have the 22 Kw charger option which is useful when charging at a hotel. 3-4 hours for a full charge. Most public chargers in Europe are 22 Kw.Do you have the 400 volt 150kW onboard charger option?
I found myself in the rear view mirror. Would be more difficult to find a local in the alps right now !The real question: did you find out what happens when you find a stranger in the Alps?
I have Porsche Charging service. I think I activated it when I collected the car. You get a RFID card by mail which you can use at most chargers, Ionity, Allego, EnwB. I have a shell recharge and some others as back up. Be sure you check the rates. Porsche charging service is best for Ionity for example.Hi, I'm planning for the same destination in a few weeks, your post was very useful.
How did you pay at all these various chargers? I installed 2-3 apps for paying in my travels in Romania but installing an app and paying online can be very time consuming abroad, especially when crossing 3-4 countries. Does Porsche provide a card to pay automatically? How do you choose to use it from within your car's PCM?
What are your tips for the right highway speed? I'd prefer to go slower if that saves the overall time, but I find it very very difficult to stay at 100-120 kmph.
I've found Chargemap Pass a good backup card to consider alongside Shell.I would order a shell recharge card and something else depending on the countries you are crossing.
And the main benefit: battery pre-conditioning on-route.It is better to travel with PCM navigation because you have a better range estimation and you know the SoC at arrival.
Are you also going to Ischgl/ Galtur or to another ski resort ?Hi, I'm planning for the same destination in a few weeks, your post was very useful.
If it shows on Porsche, it usually works with the Porsche card. Although last Friday it also programmed to charge at Tesla which doesn’t work with the Porsche card.Thanks, will check the cards you two mentioned. Hoping Shell will deliver since they sold their gas stations in Romania to MOL.
I'm going in Ortisei, South Tirol/Italy. Hotel has a charger, probably 22kw or less but should be enough. I will have to search a hotel with a good charger to stop overnight.
I find ABRP to be good but I recently had a problem with it showing a new charger that didn't work, while Porsche navigationwasn't showing it. I'm thiking Porsche knows the speed of the chargers, their charging points choices look good. And I will travel alone, which makes checking ABRP difficult.
Do you add the Porsche card in the navigation panel or is it used only on its own?
You can chose the option in PCM to favorise charging stations that accept Porsche charging service. And you can activate plug and charge in PCM this works for Ionity and Fastned. You don’t have to use the Card but just plug in the cable and it recognizes the car. But I wouldn’t travel without the rfid cards and you can also activate the apps and make and account and add a credit card so you know it works if needed.Thanks, will check the cards you two mentioned. Hoping Shell will deliver since they sold their gas stations in Romania to MOL.
Looked at your trip. Quite a distance from Bucharest, 1600 km and 10 charge stops on ABRP. What does PCM in your car say when you plan the trip?Thanks, will check the cards you two mentioned. Hoping Shell will deliver since they sold their gas stations in Romania to MOL.
The PCM shows the route and the chargers but Porsche Charging is not available in my country. It will be a huge pain if I need to install a new app and activate a separate account for each plug I need to stop at. Doing that while maybe someone else waits for you is really painful.Looked at your trip. Quite a distance from Bucharest, 1600 km and 10 charge stops on ABRP. What does PCM in your car say when you plan the trip?
I was thinking the same when I entered your trip in ABRP and the chargers you would have to use. Looks like very limited 150 Kw and more charges in Roemania en Hongaria compared to Austria / Germany. . I think you can be lucky but if one is out of order you will run into trouble. You can always charge at 22 Kw for 4 hours and return home but that is not really the purpose.The PCM shows the route and the chargers but Porsche Charging is not available in my country. It will be a huge pain if I need to install a new app and activate a separate account for each plug I need to stop at. Doing that while maybe someone else waits for you is really painful.
I'm considering if it's wise to do international trips with a Taycan.
