Wireless Carplay disconnects during 'spirited' driving.
amazing
Matthew
Asheville, NC
'99 540i, '20 Merc Sprinter 4x4, 21 Taycan 4S
I'm having an issue where when I drive at high speeds on curvy roads, exerting high g-forces on the car that wireless apple carplay with disconnect. Am wondering if anyone else has that problem, and if it's possible to make a wired connection to carplay through one of the usb-c connectors in the center console.
struther
Brad
Toronto
Nissan GTR, Nissan 350z
This is new. You are driving so fast Wi-Fi can’t keep up with you!
Plugging it in may help. I am able to plug mine in and it seems to work wired. I have never had this issue though. I have had CarPlay drop several times though due to bad coverage or general wonkiness.
NC_Taycan
Lewis
Wake Forest, NC
Unless your phone is flying around loose in the cabin there is no reasonable explanation for this. An unreasonable explanation is that the PCM's WiFi antenna connection is loose. Yes plugging into one of the console USB-C ports works great.
amazing
amazing
Matthew
Asheville, NC
So, is there anything that needs to be done other than plug in to USB-C? Will the wired connection just over ride the wifi?
It might be helpful to start another thread, because I now think it might have something to do with lossless audio. This problem seems to be exacerbated by 1) curvy roads 2) poor cell reception and 3) lossless audio setting on apple music.
I have songs that are "downloaded" but there seems to be some buffer underrun or something that the PCM is having a problem transferring all the bytes over WIFI.
NC_Taycan
Lewis
Wake Forest, NC
Somewhere on this forum someone posted the supported media formats and bit rates. It's possible your lossless format is indeed more than what the PCM can take, or it's possible it's more than can be jammed reliably over WiFi inside the car (even short range). If it's the latter problem, the wired connection should clear it up instantly.
