Difference Turbo vs. Turbo S : Boost function
Discussion in 'General Topics' started by Eisbärenhöhle, Sep 7, 2019.
  1. Eisbärenhöhle
    Eisbärenhöhle Well-Known Member
    Vehicles:
    ... clearly too many of them
    Mar 26, 2019
    Germany
    77
    #1 Eisbärenhöhle, Sep 7, 2019
    Hi all!
    Both - Turbo and Turbo S - have 625 PS .... there is only a difference in Boost mode .. but how does it work?
    Porsche tells that the Boost mode is working during Launch control ... does it mean only at Launch control is a difference between Turbo and Turbo S (performance wise)?
    But why there is so a big range difference between them? ...
    Does anybody know an answer? ... how to boost during driving? ... does it boost on full throttle automatically for 2.5s?
  2. Snake
    Snake Active Member
    Vehicles:
    BMW 530e, MB S 63 Coupe AMG, MB CLS 63 AMG, Audi R8, BMW 330i, Audi TTS, VW Golf
    Jun 19, 2019
    Germany
    Compare time from 60-100 after boost is done. 4S is quicker.
    there was an German article about the differences. 4S has a different front engine with more NM.
  3. Snake
    Snake Active Member
    Vehicles:
    Jun 19, 2019
    Germany
  4. charliemathilde
    charliemathilde Well-Known Member
    Vehicles:
    911
    Aug 11, 2019
    CA
    261
    205
    there are more albeit small differences. The regular turbo has a lower drag coefficient and smaller tires. Those significantly impact the range.
  5. OHWHATDA
    OHWHATDA Member
    Vehicles:
    Audi A4
    May 14, 2019
    Turbo S is significantly wider (so worse drag coefficient which impacts range). Also bigger tires.
    charliemathilde likes this.
  6. OP
    Eisbärenhöhle
    Vehicles:
    Mar 26, 2019
    Germany
    77
    Where did you read or heard this? .... both have same dimensions .... Turbo S is (really) slightly lower ... but not wider
  7. Scott Allen
    Scott Allen Member
    First Name:
    Scott
    Vehicles:
    2006 911 Carrera S Cabriolet, 2017 Range Rover HSE, 1967 Camaro RS/SS 396
    Jan 6, 2019
    Erie, PA
    I just looked at the Porsche configurator and both models show identical dimensions.
  8. OHWHATDA
    OHWHATDA Member
    Vehicles:
    Audi A4
    May 14, 2019
    I tried to find my source, but since I’ve read maybe 20 different articles since the Taycan launch that’s going to be hard. It may have been a mistake on my part.
  9. TheSnape
    TheSnape Well-Known Member
    Vehicles:
    Ford Fiesta
    Feb 22, 2019
    UK, London
    524
    380
    Apparently the Turbo S is slightly lower than the Turbo
  10. OP
    Eisbärenhöhle
    Vehicles:
    Mar 26, 2019
    Germany
    77
    I knew it all along : my English is limited ....
  11. BobM
    BobM Member
    First Name:
    Bob
    Vehicles:
    Tesla Model S, BMW E36 M3
    Aug 28, 2019
    Wales, UK
    The majority of the range difference between Turbo and Turbo S will be the 20" versus 21" wheels. Bigger wheels have quite a significant impact on range.
  12. Mike V
    Mike V Member
    First Name:
    Vehicles:
    918, Panamera Turbo S e-Hybrid, (+wife's Tesla Roadster 1.5 & Model S P100D)
    Dec 17, 2018
    Cincinnati, OH
    The width and construction of the tires are the difference. The 21" tires are 20mm wider and are more "sport" oriented in design and "energy efficiency class C". The narrower 20" tires are compounded for better range instead of sporty grip and are "energy efficiency class B".
    The higher "energy efficiency" results in about a 9% improvement in range due to rolling resistance for the 20" setup.
  13. OP
    Eisbärenhöhle
    Vehicles:
    Mar 26, 2019
    Germany
    77
    I found on Porsche website the 80-120 km/h times ... Turbo 1,9 seconds ... and Turbo S 1,7 seconds ... not so bad
  14. Vim Schrotnock
    Vim Schrotnock Well-Known Member
    First Name:
    Vim
    Vehicles:
    Porsche Panamera GTS
    Oct 20, 2018
    Cincinnati
    166
    168
    OK, then this says the 'boost' mode is not just for launch control???
    TheSnape likes this.
  15. Snake
    Snake Active Member
    Vehicles:
    Jun 19, 2019
    Germany
    No, the S has a different Front Motor with More power.
Share This Page
