Smart lift stopped being smart
romannet
Roman
Pohorelice
Hey all, noticed yesterday that my MY 23 stopped to lift automatically on locations. Have all sw updates, so just want to ask if there can be any simple solution (delete locations for example and set again) or shall I contact dealer. It is not deal breaker to be fair, so anythibg why i would need to have car in service for a months.
Or is it just random malmfunction and start work again?
Graluy
Graluy
Bordeaux
Taycan GTS
Hello
Last Time I had this issue I Ve just disconnect my account in the PCM and then reconnect to force my PCM to synchronize with my account to be sure all services allowed are available in my car
Deletîng position can lead to issues
Hope this will work for you
SergeyIndy
Sergey
Indianapolis
This happens from time to time. As long as you have SmartLift shown in the menu.
I would just clear all locations and start over. Then delete and readd your phone.
SmartLift seem to depend on solid GPS signal and I suspect it may have something to do with GPS reading from the phone if the Car cannot get GPS signal.
romannet
Roman
Pohorelice
Hello
So basically try to switch to some guest account and then back and good? Thanks a lot.
romannet
Roman
Pohorelice
Thank you. Will test
anonymouse
Oxfordshire UK
I would try to work out whether the car has lost all smart lifting ability, or just forgotten its historic locations. What happens if you drive down a new road, set a lift point, go around the block and drive it again?
anonymouse
Oxfordshire UK
I do not have any evidence that the car can, or would, get GPS data from the phone. Either the car has GPS, or it's operating on its own inertial measurements to fill the gaps until it gets GPS again.
romannet
Roman
Pohorelice
Thank you all. Solution has been just to switch to guest profile and then back. So basically seems it could not read proper values. Now it works fine again.
romannet
Roman
Pohorelice
Simply car did not offer save new locations and did not lift on old once even if were still in system, probably some communication error with GPS module
