- Aug 14, 2021
- Ohio
- 2022 Taycan 4S
- #1
The vehicle unlocks immediately after being locked with the touch-sensitive Comfort Access
function of the door handle, and the driver’s key is still in the proximity range of the sensors. The
door handles first retract correctly after locking, but then directly extend again and the vehicle remains
unlocked.
Cause: The cause of this behavior may be due to tolerances in the sensors of the door handles in combination
with modified software. Only door handles with software version SW 19.08 are affected by this issue
Only door handles with software version SW 19.08 can show the described fault pattern and upon complaint, must be replaced by door handles with a changed version (currently software version SW 19.04,
Door handle software version -1-)
https://static.nhtsa.gov/odi/tsbs/2023/MC-10238742-0001.pdf
Note: same problem but different cause/remedy than earlier TSB described in this thread: https://www.taycanforum.com/forum/t...comfort-access-may-16-2022.11618/#post-169689
unlocked.
