my take awaysCharging hardware will normally reach high temperatures during prolonged use
• High ambient temperature may cause stopped, slowed, or derated charging sessions
•The optional Charging Dock (7PP.915.706.A) traps multiple heat sources (receptacle, plug, supply cable, charge control unit, and part of the vehicle cable) and may exacerbate charger derating or stopped charging sessions
•The optional 7.5m vehicle cable is often wrapped around the charging dock. This further heats the charging dock during/after prolonged use, especially if the vehicle is parked close to the charging dock where less vehicle cable is needed.
•The 10 AWG supply cables are tested and certified for use in US and Canada, and may differ from other cord-and-plug EVSEs readily available in the market
•It is recommended to install or relocate installed charging hardware away from vehicle heat sources or heat exchanger exhaust air (for example, away from the Taycan front wheel opening)
