Mr.Smith
- PaulS
- Mar 1, 2020
- Southern California
- Taycan Turbo GT with Weissach VW ID.4
- #1
Nordschleife lap record: 6:55.533
What the kits includes and can be installed individually, unlike the GT3 that needs to purchases as a whole. Also confirmed the power increase is software
Aerodynamics
Downforce increased more than 3x vs. the standard car
At 200 km/h: downforce goes from 95 kg → 310 kg
At top speed: produces ~740 kg of total downforce
New rear wing with enlarged end plates
Optimised front diffuser
High-performance rear diffuser with extended fins
Enlarged air deflectors on the underbody
Carbon aerodiscs on rear wheels
Rear wing and front diffuser are adjustable (low or high downforce setup)
Top speed increased from 305 → 310 km/h
Powertrain
Max discharge current increased from 1,100 → 1,300 amps
System power output up 20 kW → 600 kW total
Max torque (Launch Control) up 30 Nm → 1,270 Nm
Attack Mode boost increased to 130 kW (10-second burst)
Peak 10-second output: 730 kW (up from 700 kW)
Suspension & Brakes
Specially tuned Porsche Active Ride system
Retuned front and rear axle steering
Retuned all-wheel drive
Larger brake discs: 440 mm front / 410 mm rear
Upgraded performance brake pads
Wheels & Tires
New 21-inch forged aluminum "Manthey" wheels — lighter than standard despite being larger
Titanium wheel bolts to reduce unsprung weight
Wheels are 3+ kg lighter than the already lightweight Weissach Package wheels
Optional road-legal track tires (Pirelli P ZERO Trofeo RS): 4 cm wider at front, 3 cm wider at rear
Exterior / Visual
Exposed carbon fiber body add-ons throughout, including:
Upper and lower wheel arch vents
Front and rear wheel arch extensions
Widened side skirts
Rear wing
The official Tacan Instagram has all of the latest news. Definitely worth a follow
Aerodynamics
Powertrain
Suspension & Brakes
Wheels & Tires
Exterior / Visual
Widened side skirts
Rear wing
