Mobile Chargers on ebay?
Thanks so much.
What is the difference between 7.2V and 11V ones?
It is not voltage but kW!
The max standard AC charging power the Taycan can take is 11kW.
The PMCC EVSE is the only option that could charge to the max as it can deliver up to 22kW of power on a suitable supply.
All UK homes have single phase 7.4kW power supply which is why the PMC+ (or any standard EVSE is ideally suited to this). To get 11kW you would need a 3 phase home supply (££££) and a more powerful EVSE such as the PMCC
I assume you have single phase at home and so ignore everything else and go with the earlier advice. PMC+ or any basic EVSE.
The end.
D00notD00d
D00notD00d
Newcastle
If buying a 2nd hand charger, you may pay more for a Porsche branded one. Audi, VW etc. are similar. Or buy a branded 2nd hand one as recommended by your electricity supplier such as Ohme, which is compatible with Octopus. New Ohme chargers are around £530.
