tomdfw1
- Tom
- Oct 26, 2021
- Plano
- 2019 Lamborghini Huracan Performante Spyder
- #1
The mobile charger is semi-smart. When it is attached to a 50A circuit with the "dryer" plug/220V the charger automatically sets itself to charge at 40A.
Question 1: Why doesn't it default or all me to bump to 50A? I think it is so that it won't blow the 50A fuse and leaves 10A buffer. As I recall, you can not alter the Amps it is set at.
Now when you swap the braid out and plug it into a standard 3 prong 120V plug the Amp defaults to 6A...but you MUST bump it up to 8A or it can drain the auxiliary battery I am told.
Question 2: Why does it default to 6A if we must change it to 8A?
I have a '22 model. I was told that '22 model year's have extended software configurations and I noticed that I can actually up the Amps when plugged in a standard plug to 10 or 11A.
Question 3: Is it safe that I bump the mobile charger to 10 or 11 and not the 8 I was told in the past?
Thanks in advance.
Tom
Thanks in advance.
Tom
