356B
- #1
If PORSCHE reads this, why is the interface selection on the the Taycan so different from the previous instrument clusters of the predecessor PCM's?
2015 Panamera 4, right LED Instrument cluster: When you use the right steering wheel control wheel, you can roll through the various choices of Navigation, Map, Media, Information, etc..... A simple roll of the wheel shifts to each screen, quick and easy without having to make any selection.
In the Taycan, for Each Tube you roll the steering wheel selection knob and a list of selections are shown, which require a look and a second push of the roller wheel to select the information. You have to look down and read the choice versus the Panamera just flipping to another screen.
Having just completed a rally on some back roads, a simple rolling between Information and trip would be very helpful and require less concentration from the driver. Roll back and forth between info screens, not roll-read-click.
One more question....
Does anyone find the Taycan instrument cluster information density to be rather sparse? As an Example, on my 2009 911S, tire pressures are on the bottom of the Tach. Tire pressures are an entire Tube 1 screen in the Taycan.
-- On the Tube 3 Taycan display, it would be good to show energy consumption Kwh/100miles on the "information" screen so you can see voltage, SOC and consumption rate at the same time, vice switching between screens per paragraphs above.
-- Combine performance metrics in Tube 3 and Nav or media in Tube 1.
Just a suggestion to allow more configurability of the 3 tubes to optimize info you need to drive in various situations,
-- Finally, Instrument Cluster configuration groups that allow you to preconfigure configurations of all three tubes based on your activity.
Its just software interface........ Thoughts?
