- David
- Jan 28, 2019
- Santa Cruz
- #1
this question comes up a lot - and below we have a table that breaks down the most common "sizes" of charging infrastructure - both home and commerical - I hope the column names are self explanatory - if not I'll be happy to answer questions.
the last two column cover in duration an expected charging session for two cases:
1. full charge - 5% to 100% - this is uncommon but possible - I modeled 80 kWh of capacity
2. daily charge - 45% to 85% - this is common for a large daily usage - I modeled 35 kWh of capacity
NOTE: for the charge rates 100 kW or above - the table below models the "linear" charge rate (constant) for time estimates - we all know there is taper - once you're above 70-80% SOC on the Taycan - so it will take a bit longer than the table estimates - my apologies - I didn't feel like modeling the exact charging curve because it's controlled by in vehicle software - if I feel like it I might whip up something custom - but for now - just know for charge rates 100 kW+ the estimate is best case _IF_ the charge rate were linear - actual charge rates to 100% SOC might be longer … but the estimate to 85% SOC is going to be closer to real life…as with most things YMMV - but this table is still useful to show the range of possible outcomes given different charging rates.
enjoy!
enjoy!
