LovinTaycan
- Feb 24, 2020
- Austin, Texas
- 2021 Porsche Taycan and 2019 Mercedes S560V
When I got my 2020 Taycan, I was so upset I could not get the 19.2 kW because I was originally told if I wait a few months, it would be available. That, of course, never happened, so I ordered my car with the 9.8 kW charger.I removed the 22kW charger from my order. I do think it requires 100 amps and needs hardwiring, and this may not even be possible in some older homes.
The faster charging speed initially sounded nice, but the majority of the time the car will charge back to 85% over night when I have much more than 4 hours available to charge. Add to the fact that Level 2 chargers are appearing at workplaces, shopping centers, etc and fast chargers are available which can deliver up to 85% in 20 minutes...I just don’t see the need for 4 hour charging at home. Especially since most of the time I’d be topping it up frequently. Slower charging is typically better for long term battery health too.
I also changed my mind on the PMCC and the dock after visiting this forum. You can get other EVSEs that have excellent reviews for half the price. Some of those have a track record of delivering 22kW if you do decide to go with the onboard charger upgrade.
I have been using this charger for months, and I believe you are correct that you really don't need it, especially at home. I almost never run the battery down that much, and I have never had an instance where it didn't have enough time to fully charge overnight, even when it was almost empty.
That being said, on my 2021 Taycan, I did order the 19.2 kW simply because it was available and now I would like that charger. I recently renovated my home, so I actually have several 100 AMP circuits ran in my garage, so it's not a problem for me. That being said, I will probably never use the capacity.
I doubt you will be unhappy with your decision.
