4S suspension height taller than Turbo or Turbo S?
rstr
Poland
Does anyone knows if 4S sits with its' suspension, by default, higher than Turbo or Turbo S? Always, when I look at 4Ses they seem to sit higher.
MissionC
MY2020 Taycan 4S
I don’t think there’s any difference. They both use the same PASM system and components. In the photo below, can you tell which one is a Turbo based on its stance?
Porsche Taycan 4S suspension height taller than Turbo or Turbo S? 9C54EC17-40CA-4C3A-A8DE-154497490C1C
Siress
Tony
Austin Texas
2020 Taycan 4S, 93 928GTS, 94 911 C2, 93 500E
There are 4 height settings, high, normal, low and extra low. The car automatically moves between normal and extra low on the freeway, you have to manually lift to high. It will lower to normal at a certain speed
Persuader
No difference.
wmras
Bill
Oregon
May be visual perception due to fatter tires (more black).
rstr
rstr
Poland
Thanks guys, for clearing this up :) It was probably a wrong impression
BenJL
Paris
You may be right! The Turbo S are lower according to the brochure.
Persuader
That's only because the Turbo S has 21" wheels as standard which with tyres have a slightly lower diameter to the 19"/20" setups and therefore makes the car slightly lower. This effect will also be the same if you spec 21" wheels on the 4S or Turbo. Very minimal though.
