For those in CA - https://licenseplatewrap.com/.Stickers as plates are illegal everywhere in the US (I believe) and more likely to get you pulled over than no plates. If the officer wants to stick it to you I'd wager stickers could be construed as fraudelent or counterfeit plates with the intent to deceive. No front plate is just a simple fix it ticket.
Run official DMV plates on the front or no plates.
FWIW I can confirm the as-sold Sto-n-Sho Taycan model fits the 2022 Taycan Cross Turismo.Has anyone used the sto n sho on a 2022 Taycan? I just ordered one and it clearly states 2020 Taycan. Their site does not have a 2022 option.
thanks. I emailed them and also my dealer. both think it will fit on the 2022 Taycan. We will find out shortly!FWIW I can confirm the as-sold Sto-n-Sho Taycan model fits the 2022 Taycan Cross Turismo.
If your dealer is doing the fitting, make sure they save the torx fasteners that get replaced by the Sto-n-Sho lag bolts.thanks. I emailed them and also my dealer. both think it will fit on the 2022 Taycan. We will find out shortly!
I "installed" it on my 2021 Taycan - took all of 2 min.thanks. I emailed them and also my dealer. both think it will fit on the 2022 Taycan. We will find out shortly!
@285kph Acknowledging - the actual mounting process is trivial. In some states in the USA, a new car must undergo state mandated ‘inspection’ before the car can be delivered. In Massachusetts, for example, you must pay for the car first, then ownership is registered with the state, then the state mandated inspection happens. Along with other checks, the plates must be mounted properly to pass the inspection. Only after that can the car be delivered to the buyer.I "installed" it on my 2021 Taycan - took all of 2 min.
I’m not very handy and don’t have a jack. Do I need to jack up the car to install the sto N sho?I "installed" it on my 2021 Taycan - took all of 2 min.
A jack is not necessary. You could raise the air suspension (if your model has it) for convenience, You’ll need a torx driver and socket wrench for the fasteners.I’m not very handy and don’t have a jack. Do I need to jack up the car to install the sto N sho?
that is awfulFor those in CA - https://licenseplatewrap.com/.
eek... i just order one as well, please let me know what they told you.So I received the Sto N Sho for my 2022 Taycan this week, but when I tried to install it, the pre-drilled holes are not in the correct spot.
I emailed them to see if they can send me a proper one.
