Establishing connection very slow
andyd
Andy
Taycan 4S, Mclaren 570GT, Cayenne
Hi
I have 2 mobile connect chargers. One came with the Taycan and the other I bought from someone who'd had a Panemera.
The old one asks for the pin immediately and starts charging within a few seconds. The new one however takes a couple of minutes before the pin is requested and even then is a few seconds between being able to press a number. Is this slowness normal?
You can disable the PIN feature for one thing if in a secure enough area.
Is the charger in standby or fully booted and connected to the internet before connecting?
As an aside worth checking the output of the Panamera charger - which model is it as it could be lower powered than what you got with your Taycan which I assume is the standard Porsche Charger Connect Plus rather than the Porsche Mobile? Charger Connect?
andyd
Andy
Yep, it's the same output.
I'll check the status if tye charger. Thanks for that.
NC_Taycan
Lewis
Wake Forest, NC
Once you disable PLC in the newer PMCC (in two different places - you will need to log in as the service user or "tech" user to do the second one), the connection to the car is faster. You can disable the power-saving sleep if you want and that will also speed things up.
I would leave PLC connection to the car "on" as there are benefits to be had and deactivate PLC to the network only.
Slow connection is a perception but if the charger isn't sleeping and connected to WiFi then assuming no profile or timer has been set to pause charging, charging will start in a few short seconds.
andyd
Andy
Thanks for the replies. It takes 2 minutes at the moment
Kingske
New Jersey and Colorado, USA
Interesting. Which would be the benefits that come with leaving the charger-to-car PLC on?
Vehicle PCID / VIN passed to charger for authentication purposes and is captured in the charging logs. Management of charging pause when timer or profile is active - PMCC flashes blue until preset start time is reached and more comprehensive charging data displayed on My Porsche.
Also need plug and charge activated in PCM.
Kingske
I see. I have a pre-software-update MY2020 and therefore no plug & charge.
andyd
Andy
Do you know how to set it not to be in Standby ?
Yes,
Use the PMC Charger Web portal / interface and logon as user ‘Home’ (your password will be in the envelope) and go to settings or config (can’t remember which) and disable sleep.
Make sure your charger is awake and connected to your WiFi before attempting the logon.
Not checked recently but it may be possible to do this using the PMCC touch screen - if you haven’t already tried. If not, then check and don’t bother with the web portal access.
