- David
- Jan 28, 2019
- Santa Cruz
60 amp hardwired vs. 50 amp NEMA should be trivial incremental cost but a bit more (thicker wire is required for 60 amps vs. 50 amps, more copper = more expense) - unless your main panel has to be upgraded because of the 60 amp breaker - it's either no big deal to move to 60 amps vs. 50 - or it is a big deal in which case you skip it. (note the 60 amp hardwired option saves the $100 parts cost of the hubble socket so it could be push-pull in terms of cost)How much do you think it would cost for your suggestion and how much do you think it would cost having him get it to where I do 60amp hardwired? I know it varies...just trying to get an idea. Don't expect it to be super accurate.
What's the disadvantage to doing it how the electrican suggested? Slower charge times (how big of a difference)?
And thanks for the help. I'm really illiterate when it comes to electrical and would be lost without everyone's help in here ?
moving to a 60 amp hardwired install requires buying a non-Porsche EVSE - where as the NEMA approach can use the included PMC+/PMCC
60 amp EVSE will charge taycan 20% faster than 50 amps EVSE
a charging session that takes 3 hours with NEMA 14-50 EVSE will take 2.5 hours with 60 amp EVSE - a full charge from 3% to 100% will take 11 hours with a 50 amp EVSE, it will take 9 hours with a 60 amp EVSE…some people care, some people don't - most of the time it doesn't matter how long it takes to charge because eitehr way it's still done by 6 or 7 amp according to schedule.
the proposed 80 amp breaker + subpanel +++++ could be twice as much - but longer term will be cheaper/easier/faster because it will make the 2nd EVSE easier/faster/trivial and could avoid a permit and a future expensive electrician visit to upgrade the setup to handle a 2nd EVSE - but it will be more expensive that either a hardwired EVSE or NEMA 14-50/6-50 EVSE.
it's your call - but either approach is functional
