- Frank
- Aug 19, 2021
- Oxfordshire, UK
- Taycan CT4S, Ferrari 355, Merc 500E, Prius PHV
- #1
I have a question for Porsche engineering people.
I know that PDCC has active links in the ARBs to allow correction of roll.
What I have assumed is that these active links are effectively disconnected when there is no lateral “G” so the ride will be better with PDCC as well as the roll being reduced because that would give lower single wheel rates.
Is this the case? Are the links “slack” when the car is on straights or is it effectively just normal ARBs apart from cornering.
As an engineer who worked in motor racing I would have assumed effectively disconnecting the links would be the case, but sufficient people, not engineers though, have told me that it just makes the car stiffer.
This is an important question for me because I am sure with my limited driving talent the cornering improvement won’t be a big deal but with the dire roads around here a better ride would be most welcome.
It is a quite expensive option I may well not benefit from if the ARBs remain in play on straights.
