ron_b
Ron
SF Bay Area, USA
2020 Taycan 4S, Bolt EV
A very nice description by Jason Fenske (Engineering Explained) of PSCB (Porsche Surface Coated Brakes). He is showing a Cayenne but it's the same brakes as is standard on the turbo and optional on the 4S.
Porsche Reinvents The Brake Rotor - No Rust, Low Dust, No Fade!
Advertisement
TAYC4N
AM
London UK
Taycan 4S Perf Battery
£11,000 to replace them if they need replacing - no thank you :)
Miwa
Bay Area, CA, USA
I know of people that just replace the brakes with non-ceramics instead of paying for new ceramic rotors on their 911.
But without a breakdown on rotor, pad, caliper costs in those quotes, who knows.
dryii
Doug
Orlando, FL
Had I been more interested in driving the Taycan on a track maybe I would have upgraded the brakes. And with regen I don't see the rotor getting as much wear-n-tear other vehicles do.
Anyone purchasing a more expensive part today must understand that it'll be a more expensive part to replace in the future, too.
Mike V
Cincinnati, OH
918, Taycan Turbo, Tesla Model S P100D
Indeed.
A major reason to include PSCB or PCCB as the only brakes on the Taycan range is because neither of them are susceptible to rust.
My wife's Tesla Model S P100D uses the friction brakes when slowing finally to a stop and that seems to keep the brake rotors somewhat free of rust.
The Taycan braking recuperation system uses even less friction braking and would be more prone to rotor surface rust than would be common for Tesla.
Also, PSCB is apparently just as dust-free as PCCB. No downside.
wmras
Bill
Oregon
Indeed.
Though dust and braking ability are similar, there are trade-offs between Porsche PSCB and PCCB.
Lower cost is the major advantage of the Silicon-Carbide brakes (PSCB).
Less un-sprung weight, better braking, and better acceleration (less mass to spin up or slow down) are the major advantages of the Ceramic Composite brakes (PCCB).
Am a huge fan of less un-sprung weight - for any given spring stiffness, less un-sprung weight is a more comfortable ride. Was surprised to see the 10 kg (22 lb.) lower weight of the Turbo S until realizing it was most likely the lighter ceramic brakes, especially since the maximum gross weight of the Turbo S is exactly 10 kg less than the Turbo (the suspension is the maximum weight-limiting factor and moving 10 kg from un-sprung weight lowers the maximum gross weight).
TAYC4S
D
911C4S; Jaguar F-Type R
Is that true? That does not sound correct to me. I heard it is more like £2,500....
jimithing
Jimmy
USA - Mid-Atlantic
The PCCBs drop more than 10kg. The 10kg is the drop in weight in brakes + add back heavier wheel weight since the Turbo S comes with standard, wider 21s vs the 20s on the turbo. No way to know exactly how much unless/until someone weighs each set of wheels/tires.
porsche_coyote
Wiley
San Francisco, California USA
Porsche Taycan Turbo, Audi allroad, VW e-golf, BMW i3
FWIW, Dan Edmunds weighed the 20" tires/wheels from a Taycan 4S in his suspension overview
He found that the front wheel/tire was 61 lbs, and the rear was 69.5 lbs (per wheel/tire).
jimithing
Jimmy
USA - Mid-Atlantic
There's half our answer ... anyone with 21s wanna weigh their wheels?
Advertisement
ZYRUS
Advertisement
