cometguy
- Oct 18, 2018
- New England, USA
- 2018 Panamera 4 ST E-Hybrid; planned Taycan CT4
Sandy Munro's team may be the best to assess how this "over-voltage" issue could arise in a Taycan, since Porsche isn't likely to give details.Just a thought and shear speculation:
It says over voltage is the cause not overcharge. You use overvoltage as way to drive electrons and create amperage. The higher the over-voltage the greater the amperage. On a car designed to charge at 270kw, you have to drive a lot of amperage requiring a high level of overvoltage (from the charger) to drive this electron flow. The car tells the charger how high of voltage to feed it, the charger doesn’t ram more current than the car asks for. This in itself is very normal.
What can be dangerous is how many batteries are in series in a voltage run. Voltage drops off with every battery in the series (V=IR) and the last battery has the lowest overvoltage and the lowest electron absorption. To quickly charge the last battery the voltage at the first battery has to be increased until the first battery stops taking electrons. Think of it like filling an ice tray from one side overflowing water to the next ice pocket, and the next etc (not a great example but good for the idea). it makes me wonder, with how long Taycan voltage series runs are how close is the first battery to the over-voltage design margin to drive 270kw…
