McgR
- Sep 27, 2021
- Belgium
- Taycan CT 4
You can solve this by entering a new far destination and let pcm calculate the route and charge stops and cancel it again. Charge planner will only be canceled like this. Had the same. Two finger reset didn’t work. Other resets didn’t work either.Did you get to the bottom of this issue, @Kippax? - I got this exact issue over the weekend and I now can't charge beyond about 23%. I did use route guidance to get me home Saturday and the nav wanted to send me to a charger, even though I was only a mile from home - so obviously I ignored it. I've cancelled navigation, there are no charging profiles or timers set. I also saw "Charging Planer" was active in the nav settings so I un-ticked it but I still have the "Target charge was automatically set to 255%" message. Any help appreciated.
usually what you did works but sometimes it doesn’t. And you need the second work around. Stupid bug.
