DannyD
- #1
Hello. Yes, I know this is the 999th topic, pardon me, but I want a discussion about the on-board charger replacement (what I believe to be the culprit) for a car out of warranty.
Bought a used 2021 4S (with 22kw onboard charger) few days ago
and after I plugged my 1.9kw* (see P.S.) single-phased AC charger for the first time, the charging process started acting weird: the remaining estimated range started to increase by +1km every second, then after 10 seconds it started to decrease, then the house fuse tripped. Then the dreaded yellow Electrical System Fault. Imagine my horror.
Problem is the error is accompanied by car being stuck (can't enter drive/reverse) and the error won't disappear on itself, even hours after waiting and/or resetting the car and/or disconnecting the 12v battery and/or doing a two-fingers reset. From reading so many topics, my sunday-evening-conclusion is that the on-board charger is dead and is causing the permanent yellow error.
I read about many people going through multiple OBC replacements, but I assume all under warranty. What about those out of warranty? How are you dealing with having the on-board charger replaced (over and over?)? Going to the dealer tomorrow, but... what should I do if this is the case? Just accept the replacement cost, maybe over and over? What about the recent recalls regarding battery/etc, could those aid me in supporting these costs? Any chance?
*P.S.: Why did I try such a low kw charger!? Been hearing about so many fails, wanted to "start safe" (lol. was probably too safe)
