Clod Reed
Wales UK
Neptune blue Taycan GTS ST
Just Ordered A Taycan? Here Are Production Facts That Will Blow Your Mind
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 6317
Text by James Wong; Photosby Porsche
7 Jul 2022
VIEW 42 IMAGES
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 featured-article_12831
If you’ve ever been to Zuffenhausen, you’d realise it’s not what you’d expect of a car factory. It is in quite a central urban location, is a major thoroughfare for traffic and sits alongside residential and commercial developments.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706123135084
But for symbolic reasons, Porsche has chosen to work within its limitations to continue building not just its current models but also its all-electric Taycan, which required a new factory.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706122711265
Here are some amazing facts we learnt from a private tour of the Taycan factory:
Around 1 billion Euros was spent to build the new Taycan factory in Zuffenhausen.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706122717909
It is completely CO₂-neutral.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706123106188
Porsche Centre Stuttgart, which is just across from the Porsche Museum currently, will soon be relocated to make way for more production facilities.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706122659396
Driverless robots whisk parts silently around the factory.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706122853644
As part of internal feedback to further improve working conditions, the factory floor for the door-fitting part of the production line was lowered so as to make for more ergonomic working conditions as technicians fit the doors.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706123000048
You can’t tell the Taycan Cross Turismo and Sport Turismo apart on the production line visually until the final stages where body panels are fitted. Once black plastic trims are fitted - you'll know its the more rugged Cross Turismo.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706122703962
The seats of the Taycan are not made in Zuffenhausen. They are made elsewhere and then brought in.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20201022104349197
If a Taycan has red brake calipers, one can definitely tell it has electric motors on the front and rear axle - as it is not the base Taycan with only motors at the rear.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220320154122975
Taycans with the Frozen Berry colour are destined mostly for China.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706124052155
1% of all Taycans produced are road tested on the Autobahn before it goes to customer hands.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220320153316099
There are highly skilled apprentices that are able to detect just 1mm imperfection in paint after the Taycan is painted. The car would be sent back for rectification if there is this small fault.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706115717200
Emu feathers are used to brush the Taycan’s base coat so as to remove as many imperfections as possible.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706123100799
If metallic paint is specified, the Taycan receives metallic flakes from an additional robot painter.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706123059932
Every Taycan produced is unique and destined for a customer.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220320154112532
Each Taycan is fully charged before it reaches the customer.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220320153932470
For the convenience of technicians, the machine holding the Taycan chassis can rotate the car by up to 110 degrees.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706122955962
All front and rear windscreens are automatically installed by machines, and they even apply the glue by themselves. After completing the job, the glue nozzle is cleaned automatically onto a piece of tissue roll and the process repeats.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 resized-20220706122844045
McgR
Taycan CT 4
“Each Taycan is fully charged before it reaches the customer.”
Pic then shows charge at 97% ! :)
nice read!
Is that good practice. To keep it with 100% charged for a long time? Or maybe they charge it 100% just before delivery and it leaves factory with the adviced 85%?
simcity
Sean
Suffolk, UK
'23 Taycan Turbo
No doubt it is charged to 100% at some point in production to at least calibrate the BMS. Then there would be various testing and QA, movements off the line etc that would no doubt all take the SoC fi down. Then of course the car will be sitting before transport etc, so it will drop again and through the various stages of transport.
So I don't think its a literal it rolls out of the factory with 100% SoC...
Bognar67
Janos
Hungary
Taycan GTS 2022, i4 40 MS 2024, GT3 992.2 2025.
Mine arrived to the dealership with ca. 30% charge (128km range) 10 days after finished the production.
On the other hand there is a message in yellow: ‘‘Battery discharge protection is active. Battery charge 100”.
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 tempImageuzpyTR
Porsche Taycan Did You Know... Interesting Taycan Production Facts 🤓 83281CE1-11AC-4434-AD61-5DA1CFF27139_1_201_a
hitmonlee
Bay Area, United States
2020 Taycan Turbo
For those dealer-spec'ed ones, does every dealer spec their own or is it more like Porsche [INSERT COUNTRY OR REGION] specs a bunch and distribute them across the dealers?
Bognar67
Janos
Hungary
Dealer speced all, individually. No bunch distribution.
Mr. Mercedes
Australia
W223 S450, X3M40i
My car was configured by either Porche Australia or Germany, not the dealership.
The paint imperfection on the rear door (dark spot about the size of a grain of rice) was also not picked up by the QC process. And the detailer advised me it's not the first or worst he's seen on a Taycan.
Clod Reed
Clod Reed
Wales UK
That must have been before they caught and plucked the Emu???
WuffvonTrips
Paul
Up North
Taycan Turbo CT
Similarly, I think that our GB showroom cars, and maybe also demonstrators, are spec'ed by Porsche GB, and tend to be highly optioned and often in the more adventurous colour choices, to showcase/promote certain options (not necessarily what the dealerships would have chosen for saleability).
