4 zone climate control question
911GP
Taycan 4S Volcano Grey
Hello,
I had regular climate on my 4s but opted for the 4-zone for my GTS (mainly because it looks nicer in the back!). For the front, the car will start with the last used setting but in the rear the control unit needs to be turned on each time the car is started. Can this be changed so it behaves like the front?
Thanks
Gitesh
GTS ST, Macan T
Hello,
Thanks
Gitesh
Check AC sittings in the PCM which should enable front and rear compartments to be synced. Ensure the SYNC button is active to enable control of the rear to be aligned with the front.
If not then it may be a deliberate intervention to keep energy consumption to a minimum. If no rear seat occupants then no need for the AC to be on in that zone.
Murph7355
Andy
I think mine remembers what it was set to in terms of temp/fan speed/sync/auto etc. The screen just needs tapping to liven it up.
Seat heating needs actively turning on, but that's an energy saving thing that I'm fine with.
Tycan keith
Keith
Essex
Taycan turbo (and... I pace, mini, sylva jester)
Is this on the new taycan? I can switch on all 4 zones and seats remotely?
Murph7355
Andy
Check that the A/C is not in ECO mode. When it’s set to that, the rear A/C is turned off
Not on mine as far as I can tell.
Jasper4S
Jasper
Netherlands
Taycan 4s ST
Isn’t there an occupancy sensor, so no airco when nobody is sitting in the back?
rim23
I have kids in their child seats there. So my observation is that the a/c turns off
911GP
Spot on. When in Eco mode at the front (which is what I normally use), the back has to be turned on each time the car is restarted. Thank you!
