ACGNerd
- T
- Aug 22, 2021
- NJ, USA
- MY22 Taycan RWD in Frozen Blue Metallic
- #1
Hi All,
Just got my Taycan RWD over the weekend! Am trying to charge the car but found some issues.
When plug the mobile charger plus to a normal household 110v outlet, it works and it can charge the car, but it is super slow at only 0.6kw (takes ~2 hours to add 1%), making it almost useless in my use case.
I checked the mobile charger plus, it shows the 50% icon, which indicatedthat the charger is limiting the current to 50% (100% is drawing 15A and using 12A to charge, so 50% will roughly translate to 6A of current draws). 110V * 6A which adds up roughly to that 0.6kW number I am seeing.
So I tried to remove the 50% current limit, but when I switch the charger to 100% current mode. It bugged out. The charging port shows red light, and the charger also shows consistent red light on these three bottons - "Charge Status", "House Connection", "vehicle".
I checked the user manual and found out what the light indicator means, it means "Missing/interrupted ground wire". Which is confusing, as the 50% current charges flawlessly(just painfully slow). Why would it say there is a grounding issue at 100% current/amps?
Another related question I have is: the manual says depends on where I live, I can try "Deactivating Ground Monitoring". I haven't done it because I am afraid it could cause safety issues (if the ground wire actually has issues then it will be dangerous). Anyone has experience with "Deactivating Ground Monitoring"?
Any help/suggestions will be very much appreciated!
Note 1, I am still talking to my electrician for installing NEMA 14-50 plugs in the house, that has its own hassles since the wiring of the house is so strange and I only have a 100A main breaker, so that installation will take time(and a lot of cash!). In the meanwhile I have to rely on charging at home at 110V for my day to day uses, so would like to get 1.2kw working with the mobile charger plus.
Note 2, I checked the recepticles, it is not tripping, and I checked the main panel, nothing is tripping either.
