Range decrease?
Ptang
Mars, PA
2021 Taycan 4s
I have had my 2021 Taycan 4S (pre owned w 5k miles) for just a few weeks. When I first got It when I charge it to 80% it used to list 188 miles. The other day however it listed 181 miles for the same 80% charge. Today it is listing 179 miles.
has anyone had a similar experience?
Is this normal? Should I be worried?
soawjo
Taycan RWD, BMW 230i convertible
It sounds like the guessometer is adjusting to your driving style which could be more, err, adventurous than the previous owner’s. Could also be due to temperature changes. Has it got cooler where you are in the last couple of days?
Fish Fingers
Cheshire
Taycan RWD
No don't worry....
As said above, it will just be some anomoly in something (driving style / outside temperature etc etc).
Remember the 'range' guesstimate at the start of a journey is no different than in an ICE car.
What you actually achieve on the journey may be completely different due to numerous factors (is your mum driving it to the shops or are you on the start line at a track day!).
GTS ST, Macan T
Depends on the weather/ ambient temperature so I would not be concerned at this stage.
Ptang
Mars, PA
2021 Taycan 4s
Meaning it will increase in range with different temps? It is getting warmer in Pittsburgh but I didn’t think it would affect it that much.
also are people charging only to 80%?
Ptang
Mars, PA
2021 Taycan 4s
Yes I drive somewhat aggressively. That’s why we got the taycan right?
I was just checking if the battery is dying already.
also anyone have lost connections bet your phone and car with car play?
soawjo
Yes, all other things being equal (driving style, journey length, AC use) the higher the temperature the higher the expected range
I often charge above 80% but I use the car nearly every day. I believe the advice is not to charge above 80% if your taycan is sitting unused for extended periods
Fish Fingers
Cheshire
Taycan RWD
I used to generally charge to 80% but now generally charge to 85% (in line with what many on here do).
The battery already has a 10% inbuilt buffer - so it's actually less.
Exeptions are:
a long journey the next day = 100%.
Not driving it for some time = <80%.
Ptang
Mars, PA
2021 Taycan 4s
soawjo, what do you charge to every night ?
It is my primary work vehicle so I drive it Monday to Friday and it goes out probably once sat and once Sunday
soawjo
Usually between 80-90% but like @Fish Fingers if I have a long journey the next day I try to give it a full charge. I don’t aim for a specific percentage, once I go below about 60% I plug it in for charging and I have four hours of very cheap rate electricity every night. My EVSE knows this and switches on for those hours and adds about 30%
GTS ST, Macan T
85% daily when needed.
