- David
- Jan 28, 2019
- Santa Cruz
NO - 100% wrong - there is no magic - bad advice - dangerous advice - and the PMCC/PMC+ will _NOT_ magically "set themselves" to 32 amps if all you do is swap a breaker - there is no way for the PMC+/PMCC to "KNOW/DETECT" that you've swapped a breakerYou can also change your breaker from 50 amps to 40 amps. The 40 amps will give you 32 amps continuous and you can set the Porsche charger at 100%. It should perform slightly better than the Porsche charger at 50%.
OMG such bad bad bad assertion/advice - don't do it.
