ShiftyWolf
- Nov 16, 2023
- Central Florida
- 2021 Porsche Taycan 4S, 2017 Audi Q5 PP
- #1
Hey all. I had a Thinkware U1000 4K dash camera installed in my Audi and recently moved it over to the Taycan. My install hardwires to the fuses rather than doing a mirror tap.
I was surprised by how the A pillar trim safety features changed in just a few years and, even though the existing posts and photos on trim removal were helpful, I wanted to include a number of close-ups and detailed instructions to help encourage anyone who might otherwise be afraid to take this project on. I can say that running camera wiring inside the A pillar trim makes for a much nicer install and really isn't all that hard with the proper tools.
This is intended to be camera agnostic, but I'll gladly answer questions later if anyone wants to know why I went with the Thinkware over several other options.
Two very important tools you'll want before starting this project are a set of plastic trim removal tools (thanks, Amazon!) and a good compact flashlight.
And away we go!
For trim removal, start with the bottom pieces and work your way up. I removed the dashboard fuse box side panel (A) first, followed by the narrow piece (B) near the door hinge. Use the trim tools to gently pry the rubber door trim (C) away from and under the A pillar trim.
Now the part everybody seems to fear most. Gently pull the top of the A pillar trim away from the A pillar (toward the inside of the car). It will only move about 1/2 inch (12mm ) and stop. You can use the trim tools along the sides to do this or it might work with just your hands. Looking down from the top, you'll see a metal pin and tab holding the trim in place. You'll probably want the flashlight to see this best, and may also find it easier to see and work if you very gently push the headliner slightly out of your way.
Proof of VAG parts sharing above
You need to pull the tab indicated by the yellow arrow upward to release the pin from its groove. I found that one of my trim tools was perfect to get in there, hook to the tab, and pull it up.
With the metal piece removed, you can see how the trim piece fits into the A pillar (plastic tab into the hole and metal pin sliding down into the groove.
You'll see the orange braided ribbon and plastic "rivet" still holding the A pillar trim. While you could probably work with this in place, removing it is pretty simple. and makes your task much easier to accomplish.
(Story continuing in my next post)
And away we go!
