amelen
- Alex
- Dec 15, 2020
- NYC
- Website
- www.alexmelen.com
- 2021 Taycan Turbo
- #1
Porsche Surface Coated Brakes (PSCB) with Calipers in High Gloss Black $900
On the Turbo, what does this option add - is it adding the PSCB or you're just paying $900 for them to be black?
Brake system with ceramic coated brake discs (tungsten carbide). To improve the response, fading stability, and significantly reduce formation of brake dust. A further advantage is the corrosion resistance of the brake discs, with a longer service life.
- Brake discs internally ventilated
- Composite brake discs on the front axle with brackets made of Aluminum
- Front: 6-piston brake calipers with 410 mm brake discs
- Rear: 4-piston brake calipers with 365 mm brake discs
- Brake calipers in High Gloss Black
