Nachyomama
I’m going to guess the trunk and frunk liners are separate?
Yes, they are an opportunity to spend moreI’m going to guess the trunk and frunk liners are separate?
Was going to say - you want to own a Porsche or not? I've been told this is all part of the experience.Yes, they are an opportunity to spend more
And what are you going to do with that money anyways?? Better to spend it on Porsche stuff.Was going to say - you want to own a Porsche or not? I've been told this is all part of the experience.
mine have the sedan silhouette and fit with no issues. From Suncoast - SKUTAYRUBAnybody have the interior rubber mats with the CT silhouette? Got a set from dealer and they look to be the sedan version. With the regular Taycan silhouette. The trunk mat has the CT silhouette and its perfectly. The interior mats doe not fit. The holes on the mat do not align with the pins on the foot well. Dealer says there are no CT mats in their system. Is this right?
@Bry5on
Did you get a set for yours?
Thanks all.
-ThinkMac-
@ithinkmac same as above. Your rear mats might be reversed if they’re not fittingmine have the sedan silhouette and fit with no issues. From Suncoast - SKUTAYRUB
I’ve got the slate grey rubber mats which fit perfectly… the cutting of the rear ones was done with a Stanley blade.. *** as for the, having the CT silhouette I’m not sure.. I need to check..@ithinkmac same as above. Your rear mats might be reversed if they’re not fitting
Just received mine and also uses the sedan silhouette.mine have the sedan silhouette and fit with no issues. From Suncoast - SKUTAYRUB
Checked mine this morning
also the saloon/sedan silhouette
I installed mats today and no issues. Pegs aligned and the all weather mats pretty much followed the same footprint as the carpet ones I removed. The backseat mats seemed a bit larger than the carpeted ones due to the extra lip but front mats were almost identical.How is everybody's Sedan mats align with the pegs on the CT? Unless I'm doing something wrong, the sedan mats are way smaller than the carpet ones I took out, and the alignment holes don't match up.
-ThinkMac-
@Jrkennedy37
Do you have the part numbers for your mats? My dealer says they don't have any CT mats in their system.
Thanks.
-ThinkMac-
