Dublin, Ireland
www.targatrips.com
I wasn't aware of the dashcam pre-wiring option – which doesn't appear to be available in European configurators. Interestingly, it mentions front and rear cameras.
chalkrwd
FL
2022 TAYCAN RWD
Surprised that they are removing rear footwell lighting
tbinmd
Maryland
CT4, 991.2 GT3
Option for pre-wire of the dash cam is in the US configurator, $130
Speuk
Simon
Locking wheel nuts still std in UK.
Not sure there's a lot to 'learn' from this video!
I don't see the dash cam pre wire in the UK either?
No but I've driven a Taycan with the Porsche Dashcam - don't bother IMHO.
Probably another update to come to the configurator which might tweak a few things like this.
Speuk
Simon
Agreed the Porsche or should I say Audi dashcam is really poor. I'll probably add either a dual FitcamX or Blackvue when mine eventually arrives
Stewartt997
Stewart
Taycan ST4S
I'd be interested in any UK experiences of fitting a dashcam. Seems to drop insurance a reasonable amount. Does Porsche offer this as an option to fit in the UK as nothing on the configurator?
Speuk
Simon
Yes Porsche will fit the VAG dashcam for an extortionate amount of money. It looks awful.
You'd be better off getting a decent Blackvue or FitcamX installed by an independent installer. I've installed lots of dual dashcams in my BMW and Ford's over the years and will install one myself.
Oink
Norway
Taycan 4S+, M3P
There will be more changes. The configurator gets updated randomly for a few weeks after the initial MY update. Have a '21 ordered in Aug 2020 and at that time the configurator did not have blue Porsche logo in the back as an option, and a few other minor things. Those came a bit later.
sebseb
Seb
Seattle
BMW 535i
I think he forgot to mention that you only get electrically adjustable steering wheel with the 14/18 way seats if you get a GTS or higher trim. Base and 4S get manual adjustment even if you spec those seats.
On RWD and 4S when you click on the ! icon for 14/18 way seats:
Note: The steering column will be manually adjustable. Rear seats are also designed with a sporty look with modified seam pattern and elevated side bolsters.
Not something I have ever had but your local Porsche dealer will be able to fit. Can be expensive due to the time it takes. If prewiring is in place for MY23 then it could be easier and therefore cheaper. The Porsche Tequipment UK website probably has it listed.
I would think the front/back pre-wire for the dashcam should come handy when installing any 3rd party dashcam - at the very least the power should be wired in, saving more than half the work installing any dashcam. Other wiring might be reusable for video from back to front for solutions such as Blackvue, though I cannot be sure this exists since Porsche doesn't seem to have a 2CH dashcam, just recommends installing 2 single channels?
Bognar67
Janos
Hungary
Taycan GTS 2022, i4 40 MS 2024, GT3 992.2 2025.
Since the "new" PCM has been introduced in February, "new pano roof" has been introduced in April (not full model range) MY23 things are rather step backs MY22/23 in fact as:
- No rear foot lights
- No safety wheel bolts as standard
-No electric steering column below GTS trim
Only one really new thing is the cam pre wire that is nuts.
Reporting new MY for this is useless.
