Correct tyre pressure
Rayo2703
Ray
I have the 21 inch mission E wheels. Should the tyre pressure be the same on all 4 wheels? The TPM seems to indicate that they should all be 41 PSI
tbinmd
Maryland
CT4, 991.2 GT3
Check the manual, it has a big table for summer or all season tires, partial load or full load.
In the US drivers door jam has a sticker with the pressures on it.
41 list for front/rear for partial load, summer tires and 3 rear seats. 42/45 for full load.
Taycan Turbo with 2 seats in the rear
FA = front axle, RA = rear axle
Part load
Full load
FARAFARA
20-inch summer tires2.5 bar / 250 kPa / 36 psi2.3 bar / 230 kPa / 33 psi2.7 bar / 270 kPa / 39 psi2.7 bar / 270 kPa / 39 psi
21-inch summer tires2.7 bar / 270 kPa / 39 psi2.6 bar / 260 kPa / 38 psi2.9 bar / 290 kPa / 42 psi3.1 bar / 310 kPa / 45 psi
20-inch all-season tires2.5 bar / 250 kPa / 36 psi2.3 bar / 230 kPa / 33 psi2.6 bar / 260 kPa / 38 psi2.7 bar / 270 kPa / 39 psi
21-inch all-season tires2.6 bar / 260 kPa / 38 psi2.6 bar / 260 kPa / 38 psi2.8 bar / 280 kPa / 41 psi3.0 bar / 300 kPa / 44 psi
20-inch winter tires2.7 bar / 270 kPa / 39 psi2.5 bar / 250 kPa / 36 psi2.9 bar / 290 kPa / 42 psi3.0 bar / 300 kPa / 44 psi
Taycan Turbo with 3 seats in the rear
Part load
Full load
FARAFARA
20-inch summer tires2.6 bar / 260 kPa / 38 psi2.5 bar / 250 kPa / 36 psi2.7 bar / 270 kPa / 39 psi2.7 bar / 270 kPa / 39 psi
21-inch summer tires2.8 bar / 280 kPa / 41 psi2.8 bar / 280 kPa / 41 psi2.9 bar / 290 kPa / 42 psi3.1 bar / 310 kPa / 45 psi
20-inch all-season tires2.5 bar / 250 kPa / 36 psi2.4 bar / 240 kPa / 35 psi2.6 bar / 260 kPa / 38 psi2.7 bar / 270 kPa / 39 psi
20-inch winter tires2.8 bar / 280 kPa / 41 psi2.7 bar / 270 kPa / 39 psi2.9 bar / 290 kPa / 42 psi3.0 bar / 300 kPa / 44 psi
B61
Bine
SI
CT4 (9/2021)
That’s been discussed several times, try to search.
it depends on tyres and manufacturer, not (just) on wheels.
raharris
I’ve been dealing with the same - the door sticker is different to the manual and different to what I’ve seen on here and different to what the Car indicates in the app. I searched on here, and it was as still clear as mud. Right now - GoodYear all seasons on mission-e wheels and I went with 38 all round. Who knows if that‘s right :(
GTS ST, Macan T
If these are the originally factory fitted tyres and wheels then look at the data plate on the driver's side when you open the door - tyre pressures are listed there for your car.
Check also in the PCM that you have the correct wheel size and tyre type selected - this should match the plate.
