ádh mór! ?The first Taycan in Ireland to spec it.
I was using a free public 22kW charger at Lidl (cheapskate that I am) when after about an hour it stopped and went red. Hasn't charged on AC since.Must have overcooked it!
What type of AC charger are you using?
Either AC port?I was using a free public 22kW charger at Lidl (cheapskate that I am) when after about an hour it stopped and went red. Hasn't charged on AC since.
Nightmare!Both ports the same with AC.
Hope you get it sorted.Yeah, will be interesting if its a fuse or the charger itself. Will report back.
Mostly because it's a new option on MY21 cars – so you couldn't spec it on the original 2020 Taycan. And its quite a pricey option at around €1600 here in ROI.Any idea why it is not a more popular option?
Thanks for that. I live in Northern Ireland which has one of the lowest concentration of charging stations in the UK, according to something I either read online in the last week or in the latest edition of WhatCar that has special EV editorial. There are only a small handful of rapid chargers here so if I do have to charge when I'm out then in all likelihood it will be at one of the 22kW stations of which there are a reasonable number, and for now they are free to use. Having said that Northern Ireland is a small place and a full charge on a Taycan is likely to take you just about anywhere you want to go in N.I and back home the same day. It really comes down to the estimated number of times I'll be charging away from home (but in N.I.) and the value I put on my time. As you say it's not a cheap option, so I'm still sitting on the fence on that one.It doesn't make a lot of sense for home charging needs given the cost and that most people can charge overnight to 85% whilst not using the car which is more than adequate for daily use.
50kW DC charging at public locations is fairly common and so no real need for 22kW AC.
The option cost is ridiculous and to have a 3 phase supply at home (which you'll need) cost prohibitive.
Make sure you spec 150kW DC if anything to take full advantage of DC charging options in UK.
