Thanks - I have been onto MyPorsche but since the car is not connecting - the MyPorsche site keeps telling me to login from the car.It’s not down but generally unreliable at the best of times - cell connection (quality of signal) dependent. Have you tried My Porsche website (another path to your car for access)?
Thank you - I will follow up with my OPC and keep the chat updatedYou could be suffering from an OTA module failure (several folk on the forum have experienced this). If you can't login via the PCM with your Porsche ID or generally lose contact then that could be related symptoms. Typically the module is replaced and all is well after that. Why it fails is anybody's guess - it shouldn't happen!
Mine's been fine all weekend except when I wanted to pre-heat the cabin before leaving for a drive - in my case this is because of weak cell connection and when the car is idle I think it goes into a deeper sleep and takes longer to wake up before the app times out. That said there could have been maintenance over the weekend which knocked various things out of kilter - hard to tell. In true IT support fashion changes are made and rolled out without notifying the customers!
Hopefully you get a better explanation and solution than offered here.
Hmm, that's a worry plus Vodafone told me the opposite. I had a suspicion that my PVTS+ wasn't working shortly after I picked the car up last November. I had some recall work done in December and as a consequence this triggered the PVTS+ (I deliberately didn't disable it) and I got a call from Vodafone. I asked the chap if he could determine any prior issues and he was able to advise that the unit was offline for two weeks from delivery and precisely when it original came on line, when it went off and when it came back.While the remote app is a "victim" of the connectivity issues, it isn't the only thing that stops working when the car refuses to re-connect to a cell signal.
For me, the most serious is that the PVTS+ tracking service is also impacted. I've confirmed with Vodafone that when the car is having connectivity issues, they cannot see or control the car. A working PVTS+ service is a condition of my insurance – so this aspect of the problem really upsets me.
There is nothing my Porsche Centre can do – as it does not appear to be a hardware issue – but is some sort of failure on the software side. Its impossible to predict when it will occur – for me its less than 10% of the time, but its not 0% either.
The pitch for PVTS+ isn't: "we'll monitor your car most of the time".
I have rang Vodafone when car has no connectivity but when I am driving it with fobs, asking them if they can "see/ping" the car and they say that they cannot and the car isn't responding to their commands.It would also be good to be able to 'test' to provide some assurance that all is well but there is no way to achieve this other than move the car without your fob and trust that it triggers and Vodafone calls.
