Radar Detector - Hardwire Fuse Box
wemct
Georgia, USA
Porsche Taycan 4S, Aston Martin DB11 (V12), Maserati Levante S GranSport, Porsche Boxster S
This week I received my new Valentine 1 Gen 2 radar detector. I wanted to hardwire it, but didn't want to use the mirror tap. I decided to use a fuse tap to power the V2G2. The fuse box is located in the driver's footwell for US cars. Row C, slot 8 is the fuse for the Interior Mirror. The power switches on and off with the "ignition". The pink plastic covers that cover the fuses are a pain to remove. I called the dealership to ask how to remove it. I got a long speech about how it is a high voltage electric car and I shouldn't be touching anything in the fuse box. It was a useless and clueless conversation. I found a black tab at the end of the pink plastic. Even after releasing the tab, it is not easy to remove the pink cover. I broke the tab on row A. It won't make a difference since the fuses are well seated just like every other car.
Here some pictures.
redrocket
Joe
Taycan Turbo, Panamera 4S, Bimmer X3
@wemct, your instructional turned a job that I had been dreading into a piece of cake. Thank you!
T-Fury
Minnesota
Audi e-Tron and Taycan Turbo
@wemct thanks for this helpful information. As a quick question, do you have the thermally and noise insulated glass? I’ve heard this wreaks havoc with many radar detectors. I was thinking about mounting the detector in the non-insulated section near the mirror housing and hoping for the best.
wemct
wemct
Georgia, USA
  • Thread starter
  • Thread Starter
  • #5
I have the standard glass. I think a small detector like the Radenso Pro M will work in the non insulated area. Good luck. My V1Gen2 seems like it would be okay too. I feel much better running the Taycan with the detector. Waze has become too spotty lately.
Reg
@wemct
Thanks for this
Do the wires tuck in or do you have to remove pieces of trim?
And if you remove trim is there a trick about not breaking the clips?
wemct
wemct
Georgia, USA
  • Thread starter
  • Thread Starter
  • #7
@wemct
Thanks for this
Like you, I was also wary of breaking clips. That was the main reason why I didn't want to do the mirror tap method. The only panels that I removed were the covers to the fuse panels that you see in the pictures. The one for the foot well can be removed by getting your fingers under one side and gently getting the clips to release. The higher panel on the side of the dash I started on the side where it meets the doors and used a stiff piece of plastic card to avoid damaging the leather with anything too sharp. Everything else on the A pillar, door weather seal and roof trim were done by tucking the wire without removing anything.
Reactions: Reg
Reg
Terrific. Thanks. I may actually give this a try - but doing it for a dash cam.
Todd
Todd
Usa
2020 taycan 4s
Here some pictures.
Dude. So awesome you posted this. I did it step by step as you instructed. Perfection. Thx for making it so easy!!!!
Advertisement
Advertisement
