magnitude
- Heinz
- Apr 13, 2023
- North California
- 2021 Taycan Turbo
- #1
I bought the following (pricey!) screen protector set, and figured I would write a short review: https://www.suncoastparts.com/product/spftay.html
I bought the set mostly because the stock screen surface shows fingerprints like crazy (especially the lower screen), but also because I'm a bit scared of scratching the screens.
The set comes with protectors for all potential screens: Dashboard, PCM, passenger, lower screen, rear A/C control screen. PCM and passenger protectors are exactly identical. Which means your passenger display protector can also serve as a spare for the PCM!
I so far have applied only the PCM and lower screen protector. This gives me the ability to directly compare the protected PCM screen with the identical but right now unprotected passenger display right next to it.
The good stuff:
So am I happy? Overall, yes. They fulfill their duty, and overall look really good. So far their reflectiveness does not significantly bother me. I would not have done it if they weren't removable, but since they are, great.
I will probably not use the dashboard protector, but I will definitely add the one for the rear A/C display. I will probably use the passenger screen protector as a spare for the PCM display instead.
Finally, some useful hints for putting a protector on: Wear some gloves. Nylon, jeweler gloves, whatever. You'll kick yourself if you accidentally get a fingerprint on the adhesive. As for putting it on, follow the instructions. Especially, try to mostly make the protector stick in the center of the screen first. If you do, it will kind of "suck itself" onto the sides... neatly pushing out any bubbles! If you do have significant bubbles (which I had only with one), don't make the same mistake as me to try to push the bubbles out with the squeegee a lot. Instead, simply lift the protector, starting with the corner closest to the bubble, until you reach the bubble, and push it back down working from the center. The bubble will be gone. This is also where you really want to wear those gloves, as otherwise you'll easily get a fingerprint on the edge.
Finally, thoroughly clean the display first, and don't handle the protector with the adhesive covering removed to close to your clothes, to avoid trapping dust and lint on the adhesive, or generally between display and protector.
The good stuff:
- The coating of the protector is indeed much more repelling of fingerprints. They don't even show up at first. After a while they will, and you will have to clean it, but it's very different from the stock screens which effectively show after the first touch after cleaning.
- They are surprisingly easy to put on. I was expecting a nightmare of trying to push out bubbles, but the manufacturer did a really good job of creating something that effectively prevents bubbles from forming. See below for some very relevant advice on how to put them on.
- They are very thick, so offer good protection.
- The displays still look perfect, no noticeable filtering of colors or brightness or anything. But see below for reflectiveness.
- They fit pretty well. But it's not perfect: At least for the PCM and lower display protector, they are slightly narrower than the actual screen, I'd say about a millimeter. Instead of "centering" the protector, I chose to perfectly align both protectors on the left side, so that the unprotected sliver appears on the right side. Especially with the PCM screen I felt that's less noticeable, since there's the transition to the passenger display anyway. Height-wise I did not have any issue.
- The instructions (which you really should follow) say to first remove the black covering to uncover the adhesive, and then after placing the protector, remove the top blue covering that protects the protector itself. Only, it's impossible to tell which side is "black" and which side is "blue" if both are still on! I think one side was shinier than the other, but by now I've forgotten which... I had to lift a corner to check the color. Do not "test" for adhesiveness by touching.
- The display surface is now significantly more reflective than without protector. I shined a wide light against both PCM display and passenger display at once, so that the light's reflection was directly visible to me. On the protected PCM display, the light was reflected very brightly. On the unprotected display, it was very noticeably dimmed, and I could see the structure of the LED light drivers I was shining on. I highly suspect that Porsche traded anti-reflection for visible fingerprints.
- In practice, that means you do see more reflection of the car's interior when driving around, at least on a bright, sunny day. It does not bother me very much so far, though.
- The price is really steep.
