- Aug 14, 2021
- Ohio
- 2022 Taycan 4S
You are being misinformed and/or you want to misinform others.Thanks, I'm finding more and more alarming information about the charging system for the main battery and why they want you to only charge at a minimum 8a with the Porsche 120v charger in your garage. Evidently if you charge at less than 8a it will damage cells in the main battery reducing range but still posing a significant risk of fire due to the cheap on board charger in the Taycan which is still used in all models including the 2021 I just purchased. I'm losing confidence in Porsche as an elite car company.
If "they" make you use a trickle charger to let your Taycan sit for a week or two, you are paying attention to the wrong "they".I'm told the 12v lithium ion battery is used to run the electronics on the car. If this battery dies then the car is dead.
Pretty silly that an EV with a 74kW main battery must rely on a single 12v battery for its brain with no backup to the main battery which would only require a DC to DC voltage converter. Instead they make you use a trickle charger if you are going to let it sit for a week or two.
