- Aug 14, 2021
- Ohio
- 2022 Taycan 4S
- #1
“The worst case really is a car that sits in an unconditioned garage in Phoenix all summer without being plugged in,” says Scott Case, co-founder and chief executive officer of Recurrent, a startup that generates battery health reports for EV customers and dealers. “That will cook the battery really quickly.” If the car is plugged in, it can use charging power to keep its battery cool.
Cold weather also impacts EV batteries. The colder it is, the slower the chemical reactions and the less charge a battery holds. But those losses are short-term; come spring, a battery in snowy Michigan or chilly Maine will recover its full function, whereas heat can bring down maximum range in perpetuity.
“You can coach people, but you can’t say ‘Don’t live in Phoenix,’” Case says. “That one feels a little bit unfair.”
California, Florida, Texas, Arizona and Georgia are home to 56% of the nation’s battery-powered cars, according to the Department of Energy. Fortunately, nurture can neutralize much of nature’s heat handicap.
“Anywhere I can find shade in a hot Texas summer, I try to find it,” says Skyler Williams, an Austin-based entrepreneur who boned up on battery chemistry and maintenance before buying his Rivian R1S last August. “It doesn’t matter if I’m going to be in the grocery store for 10 minutes or two hours. Better safe than sorry.”
Williams also follows other good rules of thumb: He only charges at fast stations when he has to, always leaves his truck plugged in when it’s parked in the garage, seldom charges the battery past 80% and uses Rivian’s app to open the windows if he’s away from the truck on a hot day. After almost a year, his car hasn’t lost any range, which bodes well for resale value.
An EV that has slogged through a handful of Texas summers, for example, may score lower than the same model with the same mileage in a temperate climate. Conversely, a Texas driver who took all the right precautions for her EV could see a higher Recurrent score than an equivalent car in a cooler climate that’s routinely driven to empty then recharged to full, practices that add wear and tear to a lithium-ion battery.
https://www.bnnbloomberg.ca/a-heat-wave-will-cook-your-electric-car-battery-if-you-let-it-1.1944148
