thecoloradokid
- Jun 17, 2020
- Colorado
- '22 Taycan CT4s + 2023 Rivian R1T
- #1
I drove my '22 CT4S with 20 inch wheels and the new WNK1 update from Denver to Lawrence, KS this past weekend. I loaded two bikes that weighed 60lbs max on the back of the car in @bsclywilly's awesome bike rack he made for CT owners. The weather was in the mid-80's, I did not have climate control on, and did not use range mode. I was averaging 75mpg to 80mpg on the highway. There is a 4,000ft drop in elevation from Denver to Lawrence, KS as well.
As you can see, efficiency was brutal.
I wanted to compare the efficiency from my last road trip to Jackson, WY that I did in the end of July and was shocked by the difference.
Same car, but pre-WNK1 update. I only brought my 35lbs electric mountain bike and used range mode on this trip. There was no speed difference on the first leg of this trip compared to my trip this past weekend, but the car was significantly better in regards to efficiency, even with the number of mountain passes I had to cross. On the way back, I took a lot of small roads, and my average speed was much lower, which explains the killer efficiency for that 550 mile leg.
I am a little baffled by these recent results and wanted to see if anyone has seen similar results after installing the new software updates?
