EU/UK: Ongoing navigation issues [Solved with PCM v3892]
targa666
Lies
the Netherlands
‘22 Taycan 4S sedan frozenberry, H-D sportster 883 low
I reviewed the invoice, and the update costs 550€. It seems they’ll need a case to obtain that amount from Stuttgart. Pfff, Germans and their bureaucracy.
Wow. Thats a lot…
And its just turning on a computer to update the PCM i assume. Doesn’t cost much manhours
Jasper4S
Jasper4S
Jasper
Netherlands
My assumption is that the hydraulic lift that gets blocked during the update likely has a half-day or full-day tariff. Including dealer taxes, the cost will be in the few hundreds after a short period.
CT4S_uk
Taycan Cross Turismo 4S
Just had the update completed this morning. Took about 4 hours in total. The nav now seems to be working way better. The route planner actually works finally. It's no longer shutting down every 10-20 mins. Also the route planner gives you a few more options when planning your route if you select the 'adjust' button (you can now choose your preferred charging network and also the minimum charger speed). As chun said the sport sound has changed too. All good so far.
Dabz
J1.1 4S
4hrs is a very long update isn’t it, in the world of computers you could download and install an entire operating system in far less time. I wonder what’s causing it to take so long
chun
Taycan Turbo 2020, Cayman GT4
Porsche
But no, really, there is no proper update delivery pipeline for the OS. “Updates” are the files of the new PCM version copied to a usb stick; and then mounted via PIWIS; which essentially performs a copy-overwrite.
They just recently stopped including in the updates the file in which user settings are stored, so it no longer gets replaced with an empty file.
Sace
Anders
Denmark
Taycan Sport Tourismo
Still a few weeks away from my appointment but "luckily" my nav is now back to reboots every 3-5 minutes. So getting a video was easy :D Lets see if they require it when I take it in.
Midlifecrisis
Worcestershire
I don't suppose they thought to allow you to name your favourites in the navigation as a new feature? My TomTom did that 20 years ago... but on the Taycan I just see postcodes or locations. Nothing helpful to let me know which is which
Dabz
J1.1 4S
Sat in the dealer and they've taken it in to apply the update, haven't asked for videos or anything. I assume all will be updated ok
E500
Herts
Taycan GTS ST, all sorts of others
Dropped mine off this morning because they want it overnight. Sent them a video I took at the request of the service manager.
Dabz
J1.1 4S
Probably more sensible. Mine is still going, 3hrs later Apparently it's a 4GB update and doesn't have a progress indicator while being applied. I guess that's better than the old Windows ones that used to quickly move through to 99% and then sit there forever on 99%, but it seems a bit of a mistake having nothing whatsoever indicating if it's working or not.
B61
Bine
SI
Just came back from my dealer.
They run some tests and it looks thst lots od updates needs to be installed; they want to have my car for 2-3 days.
Since i can live without that, i’ll book a date in late September when they’ll have available new e-cayenne for those few days.
am i satisfied with such services?
No.
Especially having in mind that less than 3 months ago,when i changed winter tyres, i’ve been told that i have the latest versions of all software.
TonytheTaycan
Mark
Taycan CT 4S
It sounds like they've had to greenlight module software versions which were only previously available for J1.2 vehicles for this PCM update to work on J1.1, so them saying everything was up to date 3 months ago was probably true.
