Intermittent wiper judder
mandoyoda
None
Recently, my Taycan has developed an intermittent wiper judder on the down cycle.
Sometimes everything is cool, and there’s a smooth sweeping motion, but other times, it’s a judder and squeal.
I am driving for 20 minutes and everything is okay, but then the wipers, especially the driver side wiper, starts to judder for a few minutes, then everything sorts itself out and back to normal. Sometimes it comes back.
Heavy or light rain doesn’t seem to make a difference. I’ve cleaned the blade and applied silicon spray. I’ve cleaned the windscreen.
Wipers haven’t been used much over the last 18 months. I do have GTechniq glass coating but the blades didn’t judder after the application.
Maybe the wiper motor is at play, or the blade needs replacing (blade seems to be intact), or it’s the GTechniq coating, or something else.
Any thoughts or things to try would be welcome.
GTS ST, Macan T
Clean the rubber.
Put the wipers in maintenance mode and then raise to clean.
mandoyoda
None
Clean the rubber.
Thanks, but I’ve done that, and even applied a silicone coating. I think the blade isn’t sitting perpendicular to the glass.
GTS ST, Macan T
I would not have applied a coating as it can add to the judder.
The wiper blade is mostly rubber and should shape itself to the screen unless you can see gaps?
Replace the blades.
Raphie
NL
Porsche Taycan 4s (21)
Yup replace the blades, rubber gets hard/crumble and then starts to “flip” rather than “drag” 2-3 every years is normal regardless of usage.
mandoyoda
None
I’ll consider replacing the blades, but they aren’t dry or crumbling. I’ve cleaned the windscreen and blades, which has reduced the judder significantly
I noticed the blades sometimes don’t sit perpendicular to the windscreen, or maintain this position. The judder is intermittent, so maybe the arm just needs twisting / realignment.
mutanthands
N.Yorkshire
Taycan GTS, Suzuki Cara
It’s probably the GTechniq coating.
Put a bit of the coating on the wiper blade and hopefully it’ll reduce the judder.
mandoyoda
None
Thanks, but I’ve already applied the GTechniq to the blade when I first applied the coating to the windscreen. I remember the blades being smooth.
I think my issue is with the arm angle and blade contact angle.
GTS ST, Macan T
I made this mistake of applying the same coating to my Boxster - judder was huge problem. Like I suggested earlier, don't use any coating.
