Lease residual with performance battery plus
tibiafx1
AC
Atlanta, GA
Taycan 4S Chalk with Stealth wrap
Does anyone know if the residual value of a Taycan 4S is higher if the car has the performance battery plus option(United States market)? This would be compared to an equally priced Taycan without the performance battery plus.
GTS ST, Macan T
Logically, yes I would have thought as there is significant value in the battery and more desirable.
Mr.Smith
PaulS
Los Angeles
RS E-Tron GT, VW ID.4 Pro
In general residuals are based on the resale of a car at auction with minimal add ons and upgrades.
4s has a higher residual than a Turbo, Turbo higher than a Turbo S.
schad
Northeast
Taycan 4S, e-tron
As far as I can tell, the PBP counts the same as any other option.
It may, and I suspect does, affect how much the dealer is able to sell the car for once you've turned it in at the end of your lease. But that's just sort of averaged in to the residual they give you. (From what I can tell it's 54% for the 4S.)
JimBob
Toronto Canada
The primary limiting factor on an EV is the range the battery provides which degrades over time. the P+ battery should be much preferred to the P battery. There probably aren't enough resale statistics to show this, but time will likely prove this to be correct.
Additionally there is now some history on battery performance over time, but not for the Taycan. Tesla, the Chevy Bolt and Nissan Leaf have enough history to know how the battery performs over time. Tesla and the Chevy bolt perform quite well over time. The Leaf doesn't because it doesn't have active cooling as the others do. The Taycan has active cooling so it will likely perform well over time.
And as the battery is the main determinant of range, why play to a weak hand by buying the small battery?
