Mobile Charger Connect stuck on connecting (110v)
paladin732
SFBay area (CA)
Taycan, Lucid
We went to use our mobile Charger Connect from our 2020 Turbo this week for the first time(we have a chargepoint flex at home) at an Airbnb without a 240v.
We set the charger up, but it seems to get stuck at "connecting" on the screen and never make it past that step. Has anyone had this problem and know how to resolve it? The car pops up the charging screen, but the bar sits at "solid green" instead of the "animated green"
My understanding is we SHOULD be able to connect at 110v through the standard outlet in the garage, but I'm wondering if that is causing a problem?
r553
Rockledge FL
981 Spyder, 2015 Cayenne Diesel, 2020 Taycan 4s
Have you ever used Mobile Charger Connect before this? It may need to be configured.
paladin732
SFBay area (CA)
Taycan, Lucid
This was the first time using it. But I think we configured it. It's fully setup and linked to our account.
epirali
Edmund
USA, East Coast
Another question have you tried unplugging and plugging it back in? Mine easily gets confused and will not proceed to charge, even at 220. It is one of the reasons I hate "smart" chargers. Dumb ones just work.
paladin732
SFBay area (CA)
Taycan, Lucid
Yep. We have plugged it in and unplugged it several times. Two different outlets, and both sides of the garage. Same behavior:
"connecting" on unit,white border on unit, green in car(static, not animated) , but not charging.
Also tried connecting to its ip to look at its stats/settings, but it has a password to login and we have no idea what the password is
NC_Taycan
Lewis
Wake Forest, NC
Password should have been on a white piece of paper in the instruction manuals in the packaging for the PMCC. That's where mine was.
paladin732
SFBay area (CA)
Taycan, Lucid
Thanks, found it in a little envelope.
Interestingly I was able to get the charging to finally work by disabling "plc connection to vehicle".
It's now charging at a whopping 0.9kw.
evanevery
Ed
Wisconsin
Does your AirBNB have a 220v electric clothes drier? Is it anywhere near the garage? ;)
evanevery
Ed
Wisconsin
You are a bit of a genius. It's right next to the garage. I'm wondering if the cable is long enough now....
Check the plug type before you get too excited....
evanevery
Ed
Wisconsin
In the event that the plug doesn't match, you might just consider tossing the PMCC rather than paying $700 for an adapter cable from Porsche (in the future).
For the price of a single Porsche adapter cable ($700) you can get a nice Mustart Travelmaster ($380) and up to 6 extra adapter cables ($49 each) to support a total of 8 different plug types (the TravelMaster comes with 2 in the box).
Nice charger, no magic BS, works well, supports both 120 and 220/240 charging, and is reasonably priced...
NC_Taycan
Lewis
Wake Forest, NC
You can also buy or build a NEMA 14-50 extension cord. Check RV supply places. Many years ago I spent < $50 on a 50' NEMA 14-50 extension and NEMA 14-30 to NEMA 14-50 adapter to charge at my brother's place. However a J1772 extension cord is more versatile - you don't have to take your PMCC with you.
evanevery
Ed
Wisconsin
I actually have one of those for my Race trailer. ...and it is significantly cheaper.
However, the reason the J1772 extension cable is a better choice is that you can leave the charger box itself inside a building (and out of any wet weather) while you run the longer weatherproof charging cable out to the car. It rained for a couple of days while I was visiting a relative (using their drier socket) and I was quite happy I could keep the charger inside where it was nice and dry. The only thing that got wet was the weatherproof J1772 extension cable itself.
Why wouldn't you need to take the PMCC (or some other charger) with you? The J1772 extension cable doesn't have one built in... Unless your destination already has one...
ACGNerd
T
NJ, USA
MY22 Taycan RWD in Frozen Blue Metallic
That's so good... I cannot get my charger to work above 0.6kW... if I remove the 6A limit the charger will just bug out...
