Sudden loss of acceleration
obxckw
Raleigh, NC
I’m driving on a local highway between 75-80mph when all of a sudden, I lose acceleration. It felt like the car just became sluggish and was quickly slowing down. Funny thing is that the interior/exterior electronics stayed on so it appears to be the acceleration that was affected. I attempted to hit the ‘gas’ pedal a few times to no avail- it just wouldn’t respond. After about 1-2 minutes of panic and plans to drift to the side of the highway, it suddenly came back to life and was normal again. The acceleration was back to normal and punchy like it should be.
I’ve read about previous recalls but this is a Taycan Turbo MY22– about a month old.
Has anyone experienced something like this?
DerekS
Derek
Frisco, TX
2023 Taycan GTS
How was your battery temperature at the time?
I had this happen once (and only once) on a hot day, under hard driving, after parking on hot cement for an hour with the A/C running. It recovered as soon as the battery cooled off.
obxckw
obxckw
Raleigh, NC
It was normal… 80-90 deg battery temp I think. Outside was nice, low 80’s at night.
Hirschaj
Jim
Austin TX
I had a strange stuttering or pulsating with minimal acceleration once. I stopped in a parking lot and turned the car off and back on. Everything was normal after that and the problem has not resurfaced but it would suck for that to happen at the wrong time.
Archimedes
Monterey
1-2 minutes of panic or seconds? If the latter, did you get a red warning in the left side dial that told you to put hands on the wheel?
obxckw
obxckw
Raleigh, NC
Looking back, it was likely 20-30 secs- everything just started to slow. No other warnings that I could see- wasn’t using cruise but am wondering if I somehow turned on Innodrive and maybe it tried to slow me to the speed limit. So odd.
GTS ST, Macan T
Was ACC, ID or Cruise with speed limits active? I had a one time experience with this and it was due to the active speed limit wrongly identifying a 40 mph zone as 30mph.
I've since never used it and have noticed on many occasions the wrong speed limit being indicated. This leads to rapid deceleration just when you least expect it.
Mapping data and signage (incorrect data or temporary speeds due to road works for example) are the general culprits rather than a fault with the car.
Cv009900
Columbus
2021 Porsche Taycan
Been there before, dealer claimed battery over heated.
to this day they had no idea why. It was a 50 degree cloudy day car was off all night.
obxckw
obxckw
Raleigh, NC
What speed limit do you have set in range mode?
I think this might be the issue. I was traveling about 80ish in a 70mph zone. I might have tried to set cruise but can't be certain and if I understand Innodrive correctly, perhaps I did have it set and if so, perhaps it saw a 70mph sign and hence may may have automatically taken over and adjusted the speed downwards. That's the only explanation I can think of.
I need to do some proactive testing and see if that's the case.
Thanks all !
Deleted member 6348
Guest
Thanks all !
When you're in Range mode, the pedal will seem like it isn't doing anything as you approach that set speed. If you floor it all the way, the speed limitation will become temporarily disabled until your speed drops below that Range mode max speed. I take advantage of that behavior all the time, because it's wonderful for passing.
Jeremy
St. Louis, MO
I don’t really use cruise control often, but I can’t think of a time where any cruise control I’ve ever used affected use of the accelerator pedal. Does innodrive disable the accelerator pedal?
