AndiL
- Andreas
- Apr 14, 2021
- Germany
- Taycan 4S, ID. 3
@chylld Well, this is nothing Porsche specific. They implemented an industry standard that a lot of other manufacturers will also implement in the future. Especially with bi-directional charging that standard is the way to go.
The problem is not that you should know all these details, but that there is a bug in the OBC that should be fixed. Maybe the WNJ8 update will improve this. The other solution would have been to tell the car to be at the target 15-30 minutes before you need it.
Update: Just want to make clear this clear. I explained how it works to help understand why the problems appeared and why even though changing to a different charger „fixed“ the issue, the original charger isn‘t the one causing the issue. Removing the HEMS would have had the same effect or disallowing using a PLC connection from the charger to the EV. But it is clear that his is quite complex for normal users and it seems to be clear what to blame. But often reality isn‘t as easy as it looks.
However it is quite flat against the wall, unlike the PWCC which sticks out far further than it has any reason to.
