Heater Replacement Costs
cb02z0
Chris
Rancho Santa Margarita
2021 Taycan (base)
First I know there are a ton of posts regarding the heater failure. I've sifted through as much as I can but what I have not been able to determine is if the replacement heater had to be paid for out of pocket. I assume yes it had to be cause Porsche will not acknowledge that they built a car with a known defect. Also, have others been charged a diagnostic fee to determine if the heater has failed? I called my local service center and they advised I would be charged $320 for the diagnostic. Seems outrageous to diagnose a problem that is easily detected via a computer but what do I know?
Thanks in advance for any wisdom shared from your experiences replacing the heater.
driver69
Ukraine
Taycan Turbo S 2021
Completely covered under warranty. Was diagnosed free of charge as well. They only charge for diagnostics if you claim there’s an issue and they’re unable to find it. At least that’s how my local dealer works.
Archimedes
Monterey
Warranty will cover all of it.
Diagnosis can be done at home. Turn on the heater. Does it blow hot air? Then it works.
snstevens
Sam
Kirkland, WA United States
Specifically - Turn the temp to the highest setting and direct the flow through the from vents. You'll be able to tell right away if you have a heater that works or not.
