- David
- Jan 28, 2019
- Santa Cruz
tire grip stops the car - not the brakes - the limit of stopping distance and power _IS_ the amount of grip your tires generate (and then limited by ABS)…not the brakes -Do the PCSB provide any additional stopping power or increase in rotor or caliper size?
at ABS limits all brakes are the same…this is why your car will take longer (time & distance) to stop on ICE than asphalt regardless of what brakes you’re using…if you want to stop in less time & distance on snow/ice you change the tires, not the brakes…same is true for non-snow/ice conditions…tires stop the car - brakes can all exceed maximum tire grip.
the difference between braking system is _NOT_ braking effectiveness (they can all invoke ABS which is tire grip threshold) - it’s braking thermal capacity and brake dust differences…stopping distance between systems is statistically insignificant until you are into brake fade conditions (which is damm near impossible to get the Taycan in a situation where you’ll have brake fade).
porsche also tests all of the braking systems to pass the same test (25 stops from 80% of top speed in row with no pause and no fade)…so all three choices pass Porsche’s “torture” test for brake design.
Taycan adds the variable of regen braking - handling 90% of Taycan’s stopping in it’s life time (according to Porsche)
so the variables are:
- appearance
- brake dust
- bragging right
you are unlikley/impossible to overwhelm _ANY_ of Porsche’s braking systems with street tires and street driving, that leaves track conditions - where the Taycan does not have enough stamina to thermally overwhelm _ANY_ of the three choices before it runs out of battery (thermals or power)…
so we’re down to what do you want to tell people you have on the car - because that honestly at this point in the only difference…
it’s one of the great triumph of Automobile marketing that they sell different brake systems, and “better” brake systems, but leave unsaid what is better about the different brake systems. Most customers assume better brakes = better stopping distance - not true - better brakes = better thermal thresholds/limits and they are better _IF_ you can overwhelm the thermal limits of standard breaks yes PCCB’s are better - but you have to measure/ask yourself when am I going to overwhelm the steel brakes? the answers is in any normal legal street driving circumstance it’s impossible to thermally saturate Porsche’s excellent steel brakes…
- yes steel vs. PCSB vs. PCCB’s all offer “upgrades” in terms of braking
- however not in a way that matters for any legal/normal street driving circumstance
- People assume better brakes = better stopping distance
- not true
- tire grip threshold (with ABS modulation) controls stopping distance not the brakes
- Porsche sells “better” braking systems but leaves “unsaid” in what aspect they are better
- they are in fact better
- but not in any way that matters for vast majority of circumstances
- the differences are in wear characteristics (Brake dust) and thermal capacity before you will experience “fade”
- normal street driving it’s difficult/impossible to envision any circumstance in which you’ll “fade” porsche’s excellent base/steel brakes…
- the Taycan is also a special case
- 90% of braking is regen
- the Taycan lacks sufficient stamina in high performance circumstances to run long enough or hard enough to need high-thermal capacity brakes
- you’ll run out of battery (power and/or thermals) before you’ll run out of braking capacity
