- Jeremy
- Feb 9, 2021
- St. Louis, MO
- 2016 Macan S; 2021 Taycan 4S; 2023 911 GTS Cab
I’m not sure if the Model 3 SRP will tell us anything about the Taycan or not.Model 3 SRP brakes are lasting 100k miles - that's a single motor too. Not saying there's more or less at play with the RWD Taycan but it's worth noting.
Are Model 3 SRP drivers using one pedal driving? Are the friction brakes used during one pedal driving or only during pressing the brake pedal?
I’ve never owned or even driven a Tesla, so I really don’t know.
Regardless, let’s look at what I do know. Besides, this thread is contrasting RWD with the 4S Taycan, so I’m focusing on that.
The AWD Taycan allocates twice as much regen for the front motor vs the rear. I also believe it uses regen before friction brakes when available.
So, when braking, I think we have one of 3 possible scenarios.
- The AWD Taycan exhausts the rear regen before adding any front regen
- The AWD Taycan adds front regen prior to exhausting rear regen and…
- The RWD similarly adds front friction brakes with the rear regen
- The RWD delays front friction brakes relative to the AWD’s use of front regen.
Scenario 2.1 means a lower braking threshold for the extra use of the front friction brakes, so even more front brake use.
Scenario 2.2 means a higher threshold again…but at the expense of (I assume) less optimal brake utilization. I assume this because if it was optimal, Porsche would employ it in the AWD.
Now…having said all that…it doesn’t mean there is a meaningful difference. Maybe it does take 100k miles before it matters. ? i said on another thread earlier that it will be interesting to watch front brake wear on RWD vs AWD.
I was just commenting that the difference exists and wasn’t mentioned.
