- Adrian
- Jan 11, 2021
- Aberdeen, Scotland
- GTS ST, Macan T
- #106
Perfect - this is pretty accurate from what I've experienced at these temps!Here is a plot of distance vs temperature I did earlier this year for a series of tests using a MY20 4S with 20 inch tires year at different temperatures under range mode showing the shape of the distance curve. The course for each test was the same and the speed was targeted at 71.5 mph under cruise control.
I may fatten the curve up as temperatures get colder or try it on some of the other drive modes. I think all the Taycans are pretty similar under similar conditions. Differences of a few per cent age points are more likely the result of slight changes in test conditions than fundamental differences between the cars.
The straight line between points is probably a pretty good approximation though it's probably a gentle curve between points. Maximum range comes around 70F at just above 300 miles which Porsche says is the optimum temperature for the car. I put the EPA and WLPT figures for the Taycan on the chart. Clearly WLPT is a better metric than EPA. There might be more current estimates than the ones I used
