NC_Taycan
- Lewis
- Oct 13, 2020
- Wake Forest, NC
- '12 Tesla Model S P85, '17 Cayenne S, '20 Taycan Turbo
Profiles set minimum charge (optionally based on GPS location).Even after reading every post I still don’t totally understand how to set this to 85%. I found the profiles and it says “general charging”. It has a option for minimum charge but not maximum? Having owned 5 Teslas in the past and one currently I find it quite amazing that if Porsche recommended charging to 85% they make it so unintuitive to set this?!?!
I’d be happy with the step by step here. Thanks
Timers set maximum charge and are not GPS-based.
The departure time in the active timer tells the car by when to achieve the specified maximum charge.
Profiles are where you can set preferred charging hours if your electricity is cheaper at night (if you don't have a time of use rate plan, look into one - it will probably cut the cost of electricity to charge your car by at least 33% if not closer to 50%). Set your departure time (in a timer) to the time of day when your electricity cost goes up. When you plug in, if your battery level is below the minimum charge configured in the active profile (remember, it can be GPS-based), the car will immediately start charging until it hits that minimum, ignoring any preferred charging times. Once it hits that minimum (or if your battery is above the minimum when you plug in) the car will wait until preferred charging hours to begin charging.
Timers also allow you to precondition the cabin at a set time.
